MHI |
MHI |
9.12.2018, 21:46
9.12.2018, 23:00
9.12.2018, 23:50
а что случилось в Словении что потребовало замнеы одной турбины? KRSKO Nuclear Power Plant (700 MW class) in the Republic of Slovenia replaced its low-pressure turbine rotor with a monoblock type low-pressure turbine from Mitsubishi Heavy Industries, Ltd. (MHI) as a measure against stress corrosion cracking in April 2006. The replacement work was completed in a very short period, 27 days, and the plant is now operating steadily with a satisfactory performance improvement. MHI longest blades, 54 inches, were fitted to this turbine for the first time in a plant. The turbine is made of low-strength material against stress corrosion cracking owing to eliminating the keyway structure and has lower stress due to its monoblock rotor. This paper reports the design, operation, and replacement work of the low-pressure turbine with 54-inch blades. |
10.12.2018, 14:30
Как производитель крупных ядерных компонент MHI действительно одна из лучших компаний.
10.12.2018, 17:34
10.12.2018, 19:31
Интересно, ПГ на Сан Онофре они тоже включили в список удач и побед? Из отчёта NRC: QUOTE However, the only similar steam generator in the country is found at the Fort Calhoun reactor; it has the only Mitsubishi steam generators in the U.S. outside of San Onofre. Так что - да, включили. На Форт-Калхун - два. На Сан-Онофре - четыре. |
10.12.2018, 19:32
Сделали? Поставили? Сколько-то проработали? |
Текстовая версия | Сейчас: 27.4.2024, 21:18 |
