24.12.2022, 15:17
#561
МАГАТЭ, вчера.
Nine mobile diesel-fuelled boilers with power in the range of 1-6.5 megawatts (MW) have been delivered to the ZNPP and are being installed, with four already operating. The nine boilers will provide about 34 MW of heating to the ZNPP site and to Enerhodar. In addition, up to 70 MW heating capacity will be provided by such boilers to be installed in Enerhodar. ZNPP has 20 fixed emergency diesel electrical power generators in stand-by mode that are ready to provide electricity if off-site electrical power is not available. To provide further redundancy and back-up capability, seven 1 MW mobile diesel electrical power generators are currently being tested and installed. Two of them are already connected to one reactor unit and are in stand-by mode. The remaining five mobile generators will be connected to other reactor units. == Доставлены семь мобильных ДГ и девять мобильных дизельных котлов. |
25.12.2022, 23:25
#562
Ветеран форума ![]() ![]() ![]() ![]() ![]() Группа: Patrons Сообщений: 1 256 Регистрация: 16.4.2019 Из: США Пользователь №: 34 767 |
МАГАТЭ, вчера. Nine mobile diesel-fuelled boilers with power in the range of 1-6.5 megawatts (MW) have been delivered to the ZNPP and are being installed, with four already operating. The nine boilers will provide about 34 MW of heating to the ZNPP site and to Enerhodar. In addition, up to 70 MW heating capacity will be provided by such boilers to be installed in Enerhodar. ZNPP has 20 fixed emergency diesel electrical power generators in stand-by mode that are ready to provide electricity if off-site electrical power is not available. To provide further redundancy and back-up capability, seven 1 MW mobile diesel electrical power generators are currently being tested and installed. Two of them are already connected to one reactor unit and are in stand-by mode. The remaining five mobile generators will be connected to other reactor units. == Доставлены семь мобильных ДГ и девять мобильных дизельных котлов. РосАтомом же? |
25.12.2022, 23:26
#563
27.12.2022, 20:08
#564
Похоже, Галущенко доверили озвучить принятое в Лондоне и Фашингтоне решение о прекращении сотрудничества Европки (про остальных не загадываю) с нами ещё в одной сфере. Интересно, сами амеры последуют принятым ими рекомендациям?
28.12.2022, 9:33
#565
Похоже, Галущенко доверили озвучить принятое в Лондоне и Фашингтоне решение о прекращении сотрудничества Европки (про остальных не загадываю) с нами ещё в одной сфере. Интересно, сами амеры последуют принятым ими рекомендациям? Газета.ру, похоже, поломалась. Там о чём речь, о топливе? Если о нём, то в Штатах ходит бумага об отказе от русского ОУП в 2025 году. И пока это не принятое решение, а предложение. Что до ЕС, то там всё сложно (для европейцев сложно). |
15.3.2023, 18:12
#566
Не нашел куда бы пристроить вопрос. Но...
для чего в ВХР используется литий? Никогда не встречал. Поясните плиз? А то в "Геоэнергетике" опубликовали пост про это... |
15.3.2023, 18:40
#567
Не нашел куда бы пристроить вопрос. Но... для чего в ВХР используется литий? Никогда не встречал. Поясните плиз? А то в "Геоэнергетике" опубликовали пост про это... Либо как выгорающий поглотитель (у американцев вместо борной кислоты соли лития-6), либо как регулятор рН (в ВВЭР вместе с борной кислотой). |
16.3.2023, 1:53
#568
Либо как выгорающий поглотитель (у американцев вместо борной кислоты соли лития-6), либо как регулятор рН (в ВВЭР вместе с борной кислотой). Хера-се вы экспериментаторы. Придется спросить у мериканцев... Если мне не изменяет память, то литий должен быть 6-м? А уж для ВХР, это ваще... Сообщение отредактировал nuc - 16.3.2023, 1:55 |
16.3.2023, 10:02
#569
Новичок ![]() Группа: Haunters Сообщений: 45 Регистрация: 21.10.2011 Пользователь №: 33 484 |
Хера-се вы экспериментаторы. Придется спросить у мериканцев... Если мне не изменяет память, то литий должен быть 6-м? А уж для ВХР, это ваще... Природный литий содержит около 7% 6-го изотопа, всё остальное - 7-й. Для корректировки рН на PWR применяется LiOH, обедненный по Li-6, т.к. из последнего в результате нейтронного захвата получается тритий, что не очень здорово. На ВВЭР LiOH не применяют, у нас в 1к дозируют КОН. |
16.3.2023, 10:17
#570
Вот вот... Литий - это американцы, у них и надо спрашивать. И, кстати, наши химики говорили, что LiOH - та ещё дрянь и для оболочек твэлов это отнюдь не айс.
16.3.2023, 11:38
#571
16.3.2023, 14:48
#572
Вот вот... Литий - это американцы, у них и надо спрашивать. И, кстати, наши химики говорили, что LiOH - та ещё дрянь и для оболочек твэлов это отнюдь не айс. С литием сталкивался только как с продуктом после облучения бериллия в отражателе. Но чтобы его в воду первого... |
16.3.2023, 15:09
#573
С литием сталкивался только как с продуктом после облучения бериллия в отражателе. Но чтобы его в воду первого... Корректировка ВХР, ничего необычного. Только что на @StranaRosatom вышла новость: QUOTE Новосибирский завод химконцентратов (входит в топливную компанию Росатома) выиграл тендер Eletronuclear на поставку 100 кг гидроксида лития-7. Он будет использоваться в системе охлаждения реакторов двух действующих энергоблоков АЭС «Ангра». Литий-7 с атомной долей изотопа не менее 99,9% добавляется в теплоноситель первого контура реакторов типа PWR для корректировки водно-химического режима. Еще он применяется в качестве основного компонента при подготовке ионообменных мембран ядерного класса, которые входят в состав оборудования для водоподготовки теплоносителя. После заключения контракта продукцию поставят до конца 2023 года. Надо понимать, "...будет использоваться в системе охлаждения реакторов" - это и есть дозирование в контур. Сообщение отредактировал kimyaci - 16.3.2023, 15:11 |
16.3.2023, 15:57
#574
16.3.2023, 22:26
#575
17.3.2023, 11:01
#576
ТВЭЛ - владелец НЗХК, а для них литий - такой же основной продукт, как и топливо. И, наверное, хорошо, что они по литию сделали некую диверсификацию (не только ради аккумуляторов). Но я бы обратил внимание на правильный посыл: поставлен изотопно чистый продукт. Это значит, разделительные мощности задействованы и здесь.
Возможно, это некий намёк нашим доброжелателям по поводу отказа от обогащения на наших мощностях?.. -------------------- С уважением
17.3.2023, 11:42
#577
Завсегдатай ![]() ![]() ![]() ![]() Группа: Haunters Сообщений: 805 Регистрация: 7.4.2015 Пользователь №: 34 148 |
Цитата они по литию сделали некую диверсификацию (не только ради аккумуляторов) на НЗХК не делают литий для аккумуляторов. Металл и хлориды лития, как и литий-7, в аккумуляторах не используются. |
17.3.2023, 13:46
#578
17.3.2023, 14:03
#579
Завсегдатай ![]() ![]() ![]() ![]() Группа: Haunters Сообщений: 606 Регистрация: 4.7.2014 Из: Moscow Пользователь №: 34 011 |
Ух ты, какие интересные подробности! И что же используется в аккумуляторах, если не литий-7, неужели исключительно литий-6? Правильно было бы написать, что для аккумуляторов изотопно-чистый литий не нужен Но, впрочем, я однажды посчитал, какую можно получить прибавку удельного импульса трёхкомпонентного ЖРД литий-фтор-водород, если вместо природного лития использовать литий-6. Оказалось - очень порядочную, дело в том, что, не только на уменьшении средней молекулярной массы, но и на уменьшении доли конденсированной фазы. До 10% можно было наиграть, если с природным литием теоретический УИ был 542 единицы, то с литием-6 - под 590. И это, безусловно, оправдывало бы затраты на разделение. Не зря такой ЖРД называли "ЯРД для бедных". Практически американцы получили только 530 (в пересчёте на вакуум). Но это был не настоящий двигатель, а экспериментальная установка для определения вообще есть ли смысл в таком аппарате. Хотя металлический литий, действительно, не используется в аккумуляторах, он нужен для одноразовых литиевых батареек. Впрочем, это всё оффтопик. |
17.3.2023, 14:53
#580
Цитата Правильно было бы написать, что для аккумуляторов изотопно-чистый литий не нужен smile.gif спасибо, добрый человек! |
| Текстовая версия | Сейчас: 3.11.2025, 10:53 |
