			  23.5.2016, 8:47
					#341
			 То есть, если я правильно понял, строительством САР (или АР-1000) должны занятся и CNNC и CGN?   Да, меня это тоже несколько удивляет. С другой стороны, была ранее информация о том, что Пекин в приказном порядке требовал от SNPTC поделиться с коллегами всей информацией по AP-1000. Возможно, это следствие.  |
			  23.5.2016, 8:52
					#342
				В любом случае, как я уже сказал, список не окончательный. Могут быть изменения и дополнения.
			  26.5.2016, 17:44
					#343
				Тайшань.
		https://www.hongkongfp.com/2016/05/26/taish...afety-concerns/ https://www.youtube.com/watch?v=EQ3xB_w2xc4 QUOTE At least seven French engineers based at the plant told FactWire that Unit 1 of the plant had already undergone a large number of tests and the soonest it could come into service would be 2018, a year later than the authorities have announced.  However, they said the Chinese authorities had been pushing hard for the construction to speed up so that it could come online in 2017 as originally scheduled and become the world’s first power plant to use third-generation nuclear technology. QUOTE A French electrical engineer at Taishan said: “The construction is delayed because of tests to be undertaken on the power generation system. Every part of the power plant needs to be tested. The soonest the plant could come online would be 2018. But we could also have to wait for another two, three, four or five years, or more. It all depends on the test outcomes and the position of the Chinese side. They want the works to finish as soon as possible.” QUOTE A French nuclear engineer with over 20 years’ experience and who specialises in nuclear reactors said: “I was based here in Taishan for three months at the end of last year. After cold tests were completed on Unit 1 on January 27, I returned to France for a one-month holiday. This time I’m back here for a year to prepare for all sorts of system checks, including steam pressure tests to be carried out next year. After that there’ll still be a lot of work to do. The earliest the plant could start up would be 2018.” QUOTE Some 200 engineers and other experts were dispatched from France to work at the Taishan plant in the first half of this month. A number of these experts have experience building nuclear power plants globally. They will soon be starting tests on the Taishan plant.
			  26.5.2016, 20:37
					#344
					![]() Ветеран форума ![]() ![]() ![]() ![]() ![]() Группа: Patrons Сообщений: 1 555 Регистрация: 17.3.2011 Из: Russia, Moscow Пользователь №: 32 515  |
				так кто будет первым?)
			  26.5.2016, 21:02
					#345
			  26.5.2016, 22:05
					#346
        			 Участник-писатель ![]() ![]() ![]() ![]() ![]() ![]() ![]() Группа: Patrons Сообщений: 5 578 Регистрация: 20.8.2012 Из: Россия, Москва Пользователь №: 33 670  |
			 так кто будет первым?) Сложно предугадать. Вот смотрите. В конце января или начале февраля в КНР летал из Франции свеженазначенный Мануэль Вальс (по-моему премьер-министр и отраслевые деятели рангом пониже). Собственно о чём я и сообщил в сообщении за №100. Вскоре появилась проникновенная статья (на китайском), может две, где говорилось о визите и сообщалось, что год - предпусковой для Тайшаня-1. Год на дворе был 2015. Затем аналогичную информацию выдал Вестингауз по Саньменю-1. Дело в том, что пошли: пролив на открытый реактор, гидроиспытания и прочая деятельность. Согласно правилам NRC, FSAR актуализируется после загрузки топлива. До этого момента это документ ни о чём. Из их учебника можно посмотреть на стр. за №30 из сообщения №699. Но, продолжались вопросы к насосам американской конструкции, плюс FOAK (банально тестов больше). Если честно, то если бы не вопросы по днищу и крышке КР, то я бы поставил на французов. И, вероятно, сделал бы ошибку. Думаю, Вест успеет первым.  |
			  26.5.2016, 22:40
					#347
			  5.6.2016, 16:09
					#348
			  9.7.2016, 11:58
					#349
				Макеты китайских кассет (CF3 и шестигранник).
		http://atominfo.ru/newsn/u0785.htm  |
			  9.7.2016, 18:43
					#350
			  9.7.2016, 18:47
					#351
				Шаровые твэлы для китайских ВТГР.
		Производство в Китае - до 30 тысяч твэлов в год.
			  9.7.2016, 18:50
					#352
			  10.7.2016, 15:59
					#353
        			 Завсегдатай ![]() ![]() ![]() ![]() Группа: Haunters Сообщений: 565 Регистрация: 25.12.2013 Пользователь №: 33 893  |
			  10.7.2016, 16:02
					#354
			 Говорят, у Маяка бОльшая часть производимых ИИИ с кобальтом-60 уходит в Китай, причем в таком темпе, что иногда в источники ставят кобальт производства НИИАР. QUOTE http://atominfo.ru/newsn/u0463.htm Мы это прекрасно знаем. Но не только в Китае дело, на кобальт-60 много потребителей. Но на самом деле - да, Китай берёт весь кобальт, до которого дотягивается.  |
			  10.7.2016, 16:04
					#355
			 Интересно, куда им столько кобальта. Например, см. по ссылке http://atominfo.ru/newsm/t0410.htm - см. главку "Изотопы".  |
			  10.7.2016, 18:39
					#356
			  17.8.2016, 10:01
					#357
				На CGN нацелились китайские угольщики (шахтёры и угольные станции).
		http://atominfo.ru/newsn/h0943.htm По нашим сведениям, CGN против, но у угольщиков большие связи в верхах.  |
			  8.9.2016, 9:00
					#358
				Тем временем в КНР произошел очередной энергопуск и синхронизация с сетью:
		В Китае подключили к сети третий энергоблок АЭС Фуцин http://www.atominfo.ru/newso/v0098.htm Дата, указанная в новости (07.09.2016) соответствует данным БД PRIS МАГАТЭ: FUQING-3. Стоит отметить, что около недели тому назад я читал о планах пустить блок во время работы саммита G20. Возможно, это было всего лишь предложение или авторский материал - информации на тот момент времени было в избытке. Блоков со статусом "Operational" теперь в КНР 36, той же датой занесено в БД начало строительства шестого Тяньваня. Сообщение отредактировал asv363 - 8.9.2016, 9:02  |
			  11.9.2016, 18:17
					#359
				Китайцы тихой сапой подбираются к месторождению урана, которое считают одним из крупнейших в мире.
		http://atominfo.ru/newso/v0139.htm  |
			  12.9.2016, 10:36
					#360
        			 Завсегдатай ![]() ![]() ![]() ![]() Группа: Haunters Сообщений: 805 Регистрация: 7.4.2015 Пользователь №: 34 148  |
				"В заявке на эксплуатационную лицензию, которая была удовлетворена, запрашивалось разрешение на добычу 3,75 миллионов фунтов (более 1700 тонн) урана в год на протяжении 18 лет - то есть, в общей сложности, более 30,5 тысяч тонн урана."
		- На Инкае уже сейчас добывается 2 тыс. тонн урана в год, весной согласовали расширение до 4 тыс. тонн в год. Это просто пример. Если смотреть их ресурсы по категории indicated, то у них ресурс 19 тыс. тонн закиси-окиси. При добыче 1700 тонн это 11 лет работы (если мне память не изменяет, каз. рудники уже столько проработали, пока не закрываются). Это если допустить, что весь-весь ресурс перейдет в запасы (обычно все же не весь). И извлечение у них около 70% (для сравнения, на Буденновском - почти 99%). И при изменении параметра cut-off очень сильно меняется ресурс - это считается не очень хорошим признаком..  |
| Текстовая версия | Сейчас: 4.11.2025, 18:12 |
