Саудовская Аравия |
Саудовская Аравия |
29.12.2017, 23:41
Модератор Группа: Clubmen Сообщений: 24 926 Регистрация: 16.1.2007 Из: Обнинск Пользователь №: 4 |
Коли саудиты начали тендерные процедуры (RFI), то можно открыть ветку.
9.9.2019, 22:48
Чтоб оправдаться за предыдущий пост, вот информация о сути соглашения 123, то, чего саудиты КАТЕГОРИЧЕСКИ не хотят подписывать
The nine nonproliferation criteria for section 123 agreements are as follows: - Nuclear material and equipment transferred to the country must remain under safeguards in perpetuity. - Non-nuclear-weapon states partners must have full-scope IAEA safeguards, essentially covering all major nuclear facilities. - A guarantee that transferred nuclear material, equipment, and technology will not have any role in nuclear weapons development or any other military purpose, except in the case of cooperation with nuclear-weapon states. - In the event that a non-nuclear-weapon state partner detonates a nuclear device using nuclear material produced or violates an IAEA safeguards agreement, the United States has the right to demand the return of any transfers. - U.S. consent is required for any re-transfer of material or classified data. - Nuclear material transferred or produced as a result of the agreement is subject to adequate physical security. - U.S. prior consent rights to the enrichment or reprocessing of nuclear material obtained or produced as a result of the agreement. - Prior U.S. approval is required for highly-enriched uranium (HEU) and plutonium obtained or produced as a result of the agreement. An agreement permitting enrichment and reprocessing (ENR) using U.S. provided material requires separate negotiation. - The above nonproliferation criteria apply to all nuclear material or nuclear facilities produced or constructed as a result of the agreement. |
9.9.2019, 23:07
21.9.2019, 20:29
Оффтоп из саудовской ветки вынес отдельно. - Модератор
http://forum.atominfo.ru/index.php?showtopic=1348 |
6.8.2020, 21:16
Тут Уолл-Стрит Журналь напечатал статейку о том, что китайцы саудитам построили тайный обогатительный заводик, на входе руда, на выходе - желтый кек
https://www.wsj.com/articles/saudi-arabia-w...ram-11596575671 Сообщение отредактировал pappadeux - 6.8.2020, 21:18 |
15.8.2020, 11:50
Жёлтый кек - это обогащение разве? Хех
15.8.2020, 12:24
15.8.2020, 15:25
17.8.2020, 0:15
А, обогащение а плохом смысле
17.8.2020, 23:22
14.10.2020, 21:59
Новичок Группа: Haunters Сообщений: 46 Регистрация: 26.9.2016 Пользователь №: 34 383 |
Королевство строит экспериментальный реактор для производства медицинских изотопов и прочего радиоактивного добра. Соответственно, им же нужны горячие камеры, чтобы выделять эти изотопы, так? Сам реактор маленький, на обычной воде и загружаемое топливо 2,1%, т.е. для производства ядерного оружия его использовать нереально (ну я так думаю, а я не техспец). А может ли атомная энергетика в СА прожить без этих камер? Ну логика такая, что ОЯТ отстаивается в бассейнах и увозится к поставщику топлива для дальнейшего репроцессинга. Может ли такое быть, что строительство мелкого реактора - это повод заполучить такие камеры? И можно ли таким образом обосновать получение камер достаточно размера, чтобы в них выделять плутоний?
Сообщение отредактировал Polit - 14.10.2020, 22:01 |
15.10.2020, 8:16
Изотопы нарабатывают не в самом топливе, а в мишенях. В камерах тоже перерабатывают мишени. Возить мишени зарубеж нет смысла, потому что изотопы, на которые есть спрос, относительно короткоживущие (то есть, распадутся, пока их туда-сюда возят).
15.10.2020, 14:09
Изотопы нарабатывают не в самом топливе, а в мишенях. В камерах тоже перерабатывают мишени. Возить мишени зарубеж нет смысла, потому что изотопы, на которые есть спрос, относительно короткоживущие (то есть, распадутся, пока их туда-сюда возят). А для локального обслуживания АЭС в Саудовской Аравии эти камеры вообще могут быть нужны? |
15.10.2020, 17:38
15.10.2020, 20:18
15.10.2020, 22:07
Для образцов-свидетелей корпуса реактора (АЭС) и пр. вполне сгодятся и "местные горячие камеры", если такой интерес у заказчика имеется. Спасибо, постараюсь поискать информацию по горячим камерам в ОАЭ. У них только АЭС, других реакторов нет, а подрядчик скорее всего будет тот же. Если в ОАЭ горячих камер не намечается, то будет маленький плюсик для подозрения в отношении саудитов. |
16.10.2020, 0:38
Рак ---бич. 21 -го века....
неависимо от цвета кожи и разреза глаз.... поэтому, на фоне всякой зеленой энергетики - именно вложение в производство коротко живущих изотопов - наиболее доходно в радиоактивном мире.... имхо. |
16.10.2020, 22:13
А что, кстати, саудовский тендер совсем заглох? Вроде до конца года что-то там обещалось произойти.
16.10.2020, 23:17
Текстовая версия | Сейчас: 28.5.2024, 2:55 |
