3 страниц V  < 1 2 3
> Саудовская Аравия
сообщение 9.9.2019, 22:48
Сообщение #41
Пользователь №: 5 621
Чтоб оправдаться за предыдущий пост, вот информация о сути соглашения 123, то, чего саудиты КАТЕГОРИЧЕСКИ не хотят подписывать
The nine nonproliferation criteria for section 123 agreements are as follows:
- Nuclear material and equipment transferred to the country must remain under safeguards in perpetuity.
- Non-nuclear-weapon states partners must have full-scope IAEA safeguards, essentially covering all major nuclear facilities.
- A guarantee that transferred nuclear material, equipment, and technology will not have any role in nuclear weapons development or any other military purpose, except in the case of cooperation with nuclear-weapon states.
- In the event that a non-nuclear-weapon state partner detonates a nuclear device using nuclear material produced or violates an IAEA safeguards agreement, the United States has the right to demand the return of any transfers.
- U.S. consent is required for any re-transfer of material or classified data.
- Nuclear material transferred or produced as a result of the agreement is subject to adequate physical security.
- U.S. prior consent rights to the enrichment or reprocessing of nuclear material obtained or produced as a result of the agreement.
- Prior U.S. approval is required for highly-enriched uranium (HEU) and plutonium obtained or produced as a result of the agreement. An agreement permitting enrichment and reprocessing (ENR) using U.S. provided material requires separate negotiation.
- The above nonproliferation criteria apply to all nuclear material or nuclear facilities produced or constructed as a result of the agreement.
сообщение 9.9.2019, 23:07
Сообщение #42
QUOTE(pappadeux @ 9.9.2019, 22:48) *
Ну и ещё, у них новый министр в лоб сказал: "Будем обогащать". Не прямо сейчас, но будем.
сообщение 21.9.2019, 20:29
Сообщение #43
Оффтоп из саудовской ветки вынес отдельно. - Модератор
http://forum.atominfo.ru/index.php?showtopic=1348
сообщение 6.8.2020, 21:16
Сообщение #44
Тут Уолл-Стрит Журналь напечатал статейку о том, что китайцы саудитам построили тайный обогатительный заводик, на входе руда, на выходе - желтый кек
https://www.wsj.com/articles/saudi-arabia-w...ram-11596575671
Сообщение отредактировал pappadeux - 6.8.2020, 21:18
Дед Мороз
сообщение 15.8.2020, 11:50
Сообщение #45
Пользователь №: 23 809
Жёлтый кек - это обогащение разве? Хех
сообщение 15.8.2020, 12:24
Сообщение #46
QUOTE(Дед Мороз @ 15.8.2020, 11:50) *
В том смысле, что ГОК.
сообщение 15.8.2020, 15:25
Сообщение #47
QUOTE(Дед Мороз @ 15.8.2020, 4:50) *
например ВостГОК - Восточный горно-ОБОГАТИТЕЛЬНЫЙ (!) комбинат
Дед Мороз
сообщение 17.8.2020, 0:15
Сообщение #48
А, обогащение а плохом смысле
сообщение 17.8.2020, 23:22
Сообщение #49
QUOTE(Дед Мороз @ 16.8.2020, 17:15) *
спустился с гор, обогатился, и обратно в горы - что же здесь плохого?
Polit
сообщение 14.10.2020, 21:59
Сообщение #50
Пользователь №: 34 383
Королевство строит экспериментальный реактор для производства медицинских изотопов и прочего радиоактивного добра. Соответственно, им же нужны горячие камеры, чтобы выделять эти изотопы, так? Сам реактор маленький, на обычной воде и загружаемое топливо 2,1%, т.е. для производства ядерного оружия его использовать нереально (ну я так думаю, а я не техспец). А может ли атомная энергетика в СА прожить без этих камер? Ну логика такая, что ОЯТ отстаивается в бассейнах и увозится к поставщику топлива для дальнейшего репроцессинга. Может ли такое быть, что строительство мелкого реактора - это повод заполучить такие камеры? И можно ли таким образом обосновать получение камер достаточно размера, чтобы в них выделять плутоний?
Сообщение отредактировал Polit - 14.10.2020, 22:01
сообщение 15.10.2020, 8:16
Сообщение #51
Изотопы нарабатывают не в самом топливе, а в мишенях. В камерах тоже перерабатывают мишени. Возить мишени зарубеж нет смысла, потому что изотопы, на которые есть спрос, относительно короткоживущие (то есть, распадутся, пока их туда-сюда возят).
Polit
сообщение 15.10.2020, 14:09
Сообщение #52
QUOTE(AtomInfo.Ru @ 15.10.2020, 8:16) *
А для локального обслуживания АЭС в Саудовской Аравии эти камеры вообще могут быть нужны?
сообщение 15.10.2020, 17:38
Сообщение #53
QUOTE(Polit @ 15.10.2020, 14:09) *
Именно АЭС? Скорее всего, нет.
сообщение 15.10.2020, 20:18
Сообщение #54
QUOTE(AtomInfo.Ru @ 15.10.2020, 17:38) *
Для образцов-свидетелей корпуса реактора (АЭС) и пр. вполне сгодятся и "местные горячие камеры",
если такой интерес у заказчика имеется.
Polit
сообщение 15.10.2020, 22:07
Сообщение #55
QUOTE(barvi7 @ 15.10.2020, 20:18) *
Спасибо, постараюсь поискать информацию по горячим камерам в ОАЭ. У них только АЭС, других реакторов нет, а подрядчик скорее всего будет тот же. Если в ОАЭ горячих камер не намечается, то будет маленький плюсик для подозрения в отношении саудитов.
сообщение 16.10.2020, 0:38
Сообщение #56
Пользователь №: 33 217
Рак ---бич. 21 -го века....
неависимо от цвета кожи и разреза глаз....
поэтому, на фоне всякой зеленой энергетики - именно вложение в производство коротко живущих изотопов - наиболее доходно в радиоактивном мире....
думаю до 7-8 % ВВП израиля доход от медицины .... ну и прочее...
имхо.
Дед Мороз
сообщение 16.10.2020, 22:13
Сообщение #57
А что, кстати, саудовский тендер совсем заглох? Вроде до конца года что-то там обещалось произойти.
сообщение 16.10.2020, 23:17
Сообщение #58
QUOTE(Дед Мороз @ 16.10.2020, 22:13) *
Конкретных новостей у нас нет. Знаем только, что процесс продолжается.
vasiliy
сообщение 16.5.2025, 7:05
Сообщение #59
Пользователь №: 33 984
С площадкой под первую АЭС вроде как определились и французы якобы даже изыскания на ней выполнили.
Интересно бы глянуть хотя бы на отчёт по ОВОС.
Или тоже "глухарь", как с Египтом?
3 страниц V  < 1 2 3
15 чел. читают эту тему (гостей: 15, скрытых пользователей: 0)
Текстовая версия Сейчас: 9.11.2025, 3:17
