| Красимир Христов |
9.10.2008, 22:58
#21
Guests |
| Гость |
19.10.2008, 9:11
#22
Guests |
Esli interesno
https://www.blogger.com/comment.g?blogID=10...061046028525621 It is also possible to safely operate a steam plant at greater than 100% of rated electrical power capacity under certain environmental conditions. If, for example, the cooling water runs several degrees colder than the design conditions, the electrical power output will increase without increasing reactor power. Rankine cycle efficiency is improved with lower heat sink temperatures. We used to make sure to find some nice cold water when proving we could make "rated turns". |
| Красимир Христов |
23.10.2008, 21:06
#23
Guests |
Esli interesno https://www.blogger.com/comment.g?blogID=10...061046028525621 It is also possible to safely operate a steam plant at greater than 100% of rated electrical power capacity under certain environmental conditions. If, for example, the cooling water runs several degrees colder than the design conditions, the electrical power output will increase without increasing reactor power. Rankine cycle efficiency is improved with lower heat sink temperatures. We used to make sure to find some nice cold water when proving we could make "rated turns". Это только подтверждает моего мнения. Другое на сайте, на мой взгляд, вольные упражнения! |
| Текстовая версия | Сейчас: 23.4.2026, 18:48 |
