#401
#402
#403
Эксперт ![]() ![]() Группа: Haunters Сообщений: 202 Регистрация: 3.5.2012 Пользователь №: 33 613 ![]() |
+1 QUOTE ВАБ - это, в первую очередь, инженерный анализ зависимостей, существующих на АЭС, включая надёжность персонала. Несовершенный, но пока единственный метод, позволяющий рассматривать АЭС комплексно как системотехнический объект во всех его взаимосвязях методами системного анализа. Наиболее важны его качественные результаты.
#404
Отнять хлеб пытаются черти.
http://arxiv.org/pdf/1504.02380v1.pdf QUOTE The industry-standard approach to the evaluation of the risk of nuclear accidents uses a bottom-up technique called probabilistic safety analysis (PSA). PSA requires the definition of failure scenarios to which probabilities and damage values are assigned. The reliability of PSA depends on the inclusiveness of scenarios as well as correct modelling of possible cascade effects, in the presence of unavoidable uncertainties. It is thus perhaps not surprising that there has been a number of incidents and accidents in the history of civil nuclear energy that failed to be properly anticipated, and in particular for cascades to be under appreciated. In [26], it was found that the probability assessments were fraught with unrealistic assumptions, severely underestimating the probability of accidents. In [5], the chairman of the World Association of Nuclear Operators stated that the nuclear industry is overconfident when evaluating risk and that the severity of accidents are often underreported. Instead of entering this quagmire, several studies have used a “top-down” approach, performing statistical analysis of historical data. These studies [39, 21, 36, 19, 16] and others have almost univer- sally found that the PSA dramatically underestimates the risk of accidents. QUOTE According to PSA specialists, the gaps between PSA-specific results and global statistical data mentioned above seem to exist in the eyes of observers who ignore the limitations in scope that apply to almost all PSA. In this view, there is nothing wrong with the PSA methodology in general, but PSA applications are often restricted to normal operation and/or to internal initiating events. In this sense, there is indeed a gap between the limited scope of PSA and the wide field of challenges to nuclear power plants. There is thus a need for more comprehensive PSA applications [29, 24] to include the uncertainties concerning the PSA numbers as well as a clear delineation of what they represent (absolute values, relative values, relative contributions...) given that the PSAs of facilities differ in their methodology and assumptions (even when following the applicable standards). QUOTE This leads to the concept that nuclear risks are unknowable because one does not have a fixed reference frame to establish reliable statistics [3]. |
#405
"показатели надежности российских атомных станций примерно в два раза лучше, чем у наших коллег и в Европе, и в Соединенных Штатах Америки". http://tass.ru/ekonomika/1948873 Отразилось ли это Заявление Руководителя на показатели - ЧПАЗ, ЧПАВ . . .? Что там в НТД говорится о показателях надежности . . ., и какие из них в два раза лучше. . . Если без шуток, то тут тренд наметился - делать ВАБ нулевого уровня! Level-0 PRA: Risk-informing the nuclear power plant I&C system by SACItM. CetIneR, MIChAeL d. MuhLheIM, GeoRGe f. fLAnAGAn, And RIChARd t. Wood смотреть тут - http://www.ans.org/pubs/magazines/nn/y_2015/m_2 |
#406
Перенёс часть постов в новую тему.
#407
Четыре дня в двадцатиром обсуждать ВАБ - это конечно очень интеесно и захватывающе, но ведь так и свихнуться можно ![]() Согласно сообщению №380, пошли навстречу трудящимся, сократили до трёх дней, все довольны. ![]() Сообщение отредактировал asv363 - 30.5.2015, 6:40 |
#408
Достаточно пустая статья Шпигеля по поводу альтернативной оценки ЧПАЗ и т.п.
В поддержку автора можно сказать только одно, ЧПАЗ обязан расти при деградации образования и отраслевых знаний и опыта. -------------------- С уважением
#409
Достаточно пустая статья Шпигеля по поводу альтернативной оценки ЧПАЗ и т.п. В поддержку автора можно сказать только одно, ЧПАЗ обязан расти при деградации образования и отраслевых знаний и опыта. |
#410
Достаточно пустая статья Шпигеля по поводу альтернативной оценки ЧПАЗ и т.п. В поддержку автора можно сказать только одно, ЧПАЗ обязан расти при деградации образования и отраслевых знаний и опыта. просто ужас, по каким помойкам Вы лазите. ![]() пробежался по другим статьям сайта ---- просто "торба" ![]() |
#411
просто ужас, по каким помойкам Вы лазите. ![]() пробежался по другим статьям сайта ---- просто "торба" ![]() В данном случае ссылку выдал гугл на первой странице. Так что не в помойке дело... -------------------- С уважением
#412
Достаточно пустая статья Шпигеля по поводу альтернативной оценки ЧПАЗ и т.п. В поддержку автора можно сказать только одно, ЧПАЗ обязан расти при деградации образования и отраслевых знаний и опыта. Ссылка не работает, а хотелось бы прочесть. |
#413
Попробуй вторую ссылку в цитате.
#414
#415
Достаточно пустая статья Шпигеля по поводу альтернативной оценки ЧПАЗ и т.п. В поддержку автора можно сказать только одно, ЧПАЗ обязан расти при деградации образования и отраслевых знаний и опыта. Предлагаю с цитируемого поста перекинуть в ветку ВАБ. Это не научная статья, рассчитанная на "широкую" публику. В ветке ВАБ об этом тоже не раз говорилось. Основной посыл результаты (ЧПАЗ и др.), получаемые по ВАБ-моделям, в ~ 10 раз "лучше" реально наблюдаемых показателей тяжелых аварий. Жванецкий рекомендовал . . ., что-то в "консерватории" подправить .. . ![]() И пример для автора цитируемого поста, если в СВРК модель восстановления линейного энерговыделения дает 300 Вт/см, а на практике "меряем" и получаем 3000 Вт/см (условно) ![]() ![]() а ВАБ - ничего "работает" . . . ![]() ![]() |
#416
barvi7, Вы правы в примере с моей моделью, и правда, не приняли бы. Как минимум потому, что результат находится не только за пределами погрешности аналогичных кодов, но и за пределами здравого смысла.
С "кочки зрения" практика по поводу статьи стоит учесть, что швайцеры всё-таки проводили оценку по всему существующему -------------------- С уважением
#417
barvi7, Вы правы в примере с моей моделью, и правда, не приняли бы. Как минимум потому, что результат находится не только за пределами погрешности аналогичных кодов, но и за пределами здравого смысла. С "кочки зрения" практика по поводу статьи стоит учесть, что швайцеры всё-таки проводили оценку по всему существующему Про "выборку" отдельная тема . . . В этой связи можно привести такой пример (с учетом некоторого "подобия" . . .) На дорогах РФ в ДТП погибает несколько десятков тысяч человек в год. Эта цифра не зависит (существенно) от типа и марки авто, дорожного покрытия и других факторов. В современных более безопасных авто погибают не меньше, чем в "стареньких" (в нормировке на тыс.км). Причины разные: больше скорость и др. Модель ДТП ВАБ дает "разумные" результаты, попадающие в наблюдаемые цифры, из года в год . . . ![]() Основой модели ВАБ ДТП - по-видимому, является не "выборка", а более ВАЖНЫЕ факторы. Тоже может быть и с ВАБ АЭС - есть более "ВАЖНЫЕ" факторы, которые в современных моделях ВАБ не учтены . . . ., отсюда и ненаблюдаемые цифры . . . |
#418
Вот это вполне может быть. В частности, более важным фактором может оказаться человеческий фактор.
#419
http://www.sussex.ac.uk/broadcast/read/36929
. . . Тем временем ученые университета Сассекса в Великобритании и Швейцарской высшей технической школы проанализировали 216 аварий в мировой ядерной энергетике и пришли к выводу, что вероятность их значительно выше, чем принято считать, и что катастрофа, сопоставимая по масштабам с Чернобыльской или аварией на АЭС Фукусима-1, с немалой вероятностью может произойти в ближайшем будущем. ![]() |
#420
http://www.sussex.ac.uk/broadcast/read/36929 . . . Тем временем ученые университета Сассекса в Великобритании и Швейцарской высшей технической школы проанализировали 216 аварий в мировой ядерной энергетике и пришли к выводу, что вероятность их значительно выше, чем принято считать, и что катастрофа, сопоставимая по масштабам с Чернобыльской или аварией на АЭС Фукусима-1, с немалой вероятностью может произойти в ближайшем будущем. ![]() Опять на ВАБ бочку катят? ВАБ - это всего лишь одна из метрик по которой происходит разговор с регулятором, я надеюсь это все понимают, в особенности регулятор это первое, а второе заключается в том что ну неопределенности в модели ВАБ ну очень большие - ну 10 это минимум, так что среднее значение ЧПАЗ - это как средняя температура по больнице. |
Текстовая версия | Сейчас: 29.9.2025, 17:46 |
