4.10.2018, 9:39
#141
Частый гость ![]() ![]() ![]() Группа: Haunters Сообщений: 335 Регистрация: 30.6.2011 Из: оттуда Пользователь №: 33 368 |
Никогда такого не было, и вот опять © График вновь будет пересмотрен. http://atominfo.ru/newst/a0329.htm Повторюсь: Передача блока (РТО) ранее 2020 года не состоится. После разделения Аревы на три части стало чрезвычайно сложно получить квалифицированный персонал на стройку. Немецкий Фраматом элементарно отказывает в командировках, мотивируя это занятостью инженеров в прочих проектах. |
5.2.2019, 23:07
#142
Ветеран форума ![]() ![]() ![]() ![]() ![]() Группа: Patrons Сообщений: 1 303 Регистрация: 23.12.2014 Пользователь №: 34 075 |
Люди твитят всякое.
The main circulation pipeline vibrates excessively under load, way over the design specification. The root cause is still unknown. The dampers that solve the problem use a bitumen base and that has to be tested to get the license. Unique to Olkiluoto. At Taishan the vibration was inside design parameters and was not an issue. One has to remember that Olkiluoto is one off EPR built to entirely different specifications than all other EPR reactors. The damper solution in itself is okay. Now they need to be sure that the bitumen does not crack and clog pipes, pumps and the reactor itself in an accident scenario where the main pipeline breaks. Actually that is the last hurdle that has to be cleared before STUK gives the go ahead and then the government can issue the license itself. They are doing round the clock testing both in Germany and at Lappeenranta Technical University to confirm the integrity of the bitumen. Olkiluoto uses a proprietary Siemens steam turbine that is a one off, the only one in the world. If something goes wrong with that one TVO has to go on their knees and beg Siemens to send them replacement parts because no one else makes them. Siemens was a part of Areva back in 05 when building began as a part of an consortium. Their responsibilty was the turbine hall and automation. The turbine hall part they managed to do but they completely screwed up on the automation side, causing yearlong delays. Siemens divorced Areva in 09 but they complete inability to make an automation system to fit our regulatory need caused about 6 years in delays. The hardware at OL3 was ready for testing back in 2014 the automation was ready to be installed first at the end of 2016. There is also a third option why TVO has not taken direct legal action against Siemens but this my guesswork. Since TVO is totally dependent on Siemens for parts and maintenance for the turbine they simply cannot afford to antagonize Siemens by taking legal action. -------------------- Всё это мелкая рябь на волнах экономических циклов, незаметных на приливах эпох.
5.2.2019, 23:34
#143
6.2.2019, 15:39
#144
Люди твитят всякое. Выглядит так, будто вибрирует весь трубопровод первого контура. На самом же деле, вибрации незначительно превысили пороговое значение лишь на участке, ведущем к компенсатору давления. Этот порог отличается от установленного для китайских блоков, и именно поэтому на Олкилуото это стало проблемой, хотя вибрации одинаковые и в Китае, и в Финляндии. Турбина уже была успешно протестирована во время горячей обкатки. По сути дела там осталось лишь отъюстировать параметры на мощности. |
6.2.2019, 18:42
#145
6.2.2019, 19:00
#146
Скорее, дополняют друг друга.
8.2.2019, 15:13
#147
Клевещут, что Олкилуото-3 "just weeks away" от получения эксплуатационной лицензии.
11.2.2019, 10:47
#148
Клевещут, что Олкилуото-3 "just weeks away" от получения эксплуатационной лицензии. В статье на главной непонятно, от выдачи или от подачи заявки на эксплуатационную лицензию. Согласитесь, это довольно разные вещи -------------------- Есть две бесконечные вещи — Вселенная и человеческая глупость. Впрочем, насчёт Вселенной я не уверен. (с) Эйнштейн
11.2.2019, 11:04
#149
В статье на главной непонятно, от выдачи или от подачи заявки на эксплуатационную лицензию. Согласитесь, это довольно разные вещи Исходно тоже не очень понятно, но мы предполагаем, что заявку удовлетворят в краткие сроки. Поэтому если к "just weeks away" прибавить ещё небольшой срок, то всё равно получится "just weeks away". |
11.2.2019, 11:13
#150
Исходно тоже не очень понятно, но мы предполагаем, что заявку удовлетворят в краткие сроки. Поэтому если к "just weeks away" прибавить ещё небольшой срок, то всё равно получится "just weeks away". Лицензия как раз не проблема. По-прежнему имеет место катастрофическое отставание по срокам сдачи документации, не позволяющее надеяться на загрузку топлива ранее конца текущего года (а, скорее всего, начала следующего). |
25.2.2019, 19:08
#151
Клевещут, что Олкилуото-3 "just weeks away" от получения эксплуатационной лицензии. http://atominfo.ru/newsy/z0206.htm Саму лицензию выдаст правительство (Минэкономики). |
25.2.2019, 20:52
#152
"Добро мы дадим, но вибрацию трубы вы всё равно должны устранить."
27.2.2019, 8:48
#153
На 20 лет лицензию могут дать. Точнее, до 2038 года.
https://www.stuk.fi/web/en/-/radiation-and-...RYqSlsw.twitter |
27.2.2019, 8:49
#154
"Добро мы дадим, но вибрацию трубы вы всё равно должны устранить." Угу. QUOTE One matter to be supervised and inspected before loading fuel is to suppress the pressurizer surge line vibration of the primary circuit detected in the test run of the plant.
There exist alternative technical solutions for that. STUK will inspect the plans for the solution chosen by Teollisuuden Voima, supervise the work and verify before the loading of fuel that the alteration works have been performed and the operability of the solution has been tested. |
7.3.2019, 22:44
#155
26.3.2021, 11:22
#156
STUK дал добро на загрузку топлива.
http://atominfo.ru/newsz03/a0370.htm |
29.3.2021, 8:48
#157
Загрузка идёт полным ходом. К концу недели должна быть завершена.
24.8.2021, 14:20
#158
1.9.2021, 10:10
#159
Боюсь, это могут быть лишь первые 3 месяца в очередной череде подобных сдвигов. Турбина механически повреждена. |
2.9.2021, 9:18
#160
Ветеран форума ![]() ![]() ![]() ![]() ![]() Группа: Patrons Сообщений: 1 598 Регистрация: 13.5.2014 Пользователь №: 33 984 |
Почему то вспомнилась старая КВНовская шутка: "Это кто стоит на месте?" (далее по тексту) |
| Текстовая версия | Сейчас: 8.11.2025, 7:37 |
